Which Spark Plug for GT40?
  • ricofrancois
    • Jan 2011
    • 26
    • Santa Monica, CA
    • 1997 Nautique 196 Open Bow PCM GT40 EFI
    Hi guys
    I have a 1997 Nautique 196 with GT40 EFI 5.8. The owner manual mentions the Motorcraft AWSM22 / Autolite 763. They've been discontinued and the replacement is according to Autolite the 764.
    I just want to make sure I get the right one. The gap should be 045, is this the case for all 764 or do they come with different gap sizes?
    Eric
    1997 Nautique 196 Open Bow - StarGazer ZBox - 5.8 GT40 EFI
  • 74green
    • Nov 2009
    • 281
    • Canyon Lake, Texas
    • 2001 Air Nautique
    I used the 764s at .045 in my 5.8 GT40
    Current: 2001 Air Nautique GT-40
    • ricofrancois
      • Jan 2011
      • 26
      • Santa Monica, CA
      Thanks, I will get the Autolite 764.
      • h2oski
        • Oct 2010
        • 49
        • Liberty Hill, TX
        • 1996 Ski 176, 1999 Air, 1977 CVX-20
        The Ford GT-40 is a 5.7 not 5.8... Chevy makes a 5.8 though... I'm just say'in
        SkiDim GT-40 spark plugs
        -Scott
        • seth
          • Jun 2008
          • 549
          • Santa Barbara, CA
          • 01 SAN-sold
          Thats weird. Im pretty sure my Gt-40 says 5.8 right on it, and it sure feels like a 5.8 rather than a 5.7.
          • ricofrancois
            • Jan 2011
            • 26
            • Santa Monica, CA
            Yes I am pretty sure mine says 5.8 and the 1997 owner manual GT40 specifications reads 351/5.8 310BHP
            • ricofrancois
              • Jan 2011
              • 26
              • Santa Monica, CA
              It looks like the 5.7 is on the 350 block not 351
                The Ford is the 5.8. The Chevy is the 5.7
                Ford bore and stroke, 4.00 X 3.500
                GM bore and stroke 4.000" x 3.48
                Sorry, the Ford has more cubic inches. It is bigger.
                • jasper
                  • Feb 2005
                  • 195
                  350 in^3 = 5.73547 L
                  351 in^3 = 5.75185 L
                  GT-40 = Ford = 351
                  • NigelC
                    • 161
                    • UK
                    • 2010 Ski Nautique 200 Open Bow Team Edition
                    I believe the PCM part number is RP030007 for a set of 8
                    2010 Ski Nautique 200 Team Edition Open Bow, Radar Strada
                    Dealer: http://www.midlandsnautique.co.uk
                    • h2oski
                      • Oct 2010
                      • 49
                      • Liberty Hill, TX
                      Dang, I knew it.... I should have sat on my hands.... I tried to help and got it backwards.... at least we know now....
                      • gtxragtop
                        • Oct 2011
                        • 56
                        • Worcester
                        From my research I've found the following:
                        I have the original factory plugs on my 1996 GT40. They are AWSF-22C. According to the autolite chart, they map to 103.
                        The 764s which map to AWSF-32C are a hotter plug and belong in the non GT40 engine which I see in my PCM manual. The
                        PCM manual states that AWSF-22C maps to Autolite 763 not 764. The 763 is no longer produced. So I plan to use 103C which should be the correct heat range for this engine to prevent detonation. The AWSF-22C in there now are burning very cleanly.
                        http://www.autolite.com/sites/defaul...ref_0311_0.pdf
                        • gtxragtop
                          • Oct 2011
                          • 56
                          • Worcester
                          103 is the standard copper core plug
                          AP103 is a single platinum plug
                          APP103 is a double platinum plug
                          I see that a number of Marine parts vendors are selling the 764 as the replacement for the GT40 engine. I suspect that they lumped the GT40 into the PCM 5.8
                          lower horsepower category by mistake.
                          • east tx skier
                            • 1561
                            • Tyler, TX
                            I have used xopper AL764 in two different high output 351s and have never had a bit of trouble. I think the lower horsepower 351s take an AL24, but memory may have faded. Let us know how the 103 world for you.
                            • gtxragtop
                              • Oct 2011
                              • 56
                              • Worcester
                              764 is one range hotter plug. With a hotter plug there is a possibility of pre-ignition (pinging) that can take place. Since it is one range hotter, probably not
                              an issue. I'll let you know about the 103. I really do not expect much difference from a 764. The AWSF-22C in the engine are the original plugs with 667 hours on
                              them and they still look new. Hard to believe they are original but given that they have a trace of black engine paint on them as if they were sprayed when the engine was sprayed at the factory leads me to believe they are original. Anyway they have the perfect very light tan color on the insulator tip so why change when they work so well.
