Where to mount a Perko switch in a 1999 Air Nautique?
  • h2oski
    • Oct 2010
    • 49
    • Liberty Hill, TX
    • 1996 Ski 176, 1999 Air, 1977 CVX-20
    I'm looking for suggestions on where to install a "perko" style battery switch in a 1999 Air/Sport Nautique?
    I'm planning on moving the 2 batteries to behind the observers seat. So I'd like to mount it near them I guess. But my concern is the positive battery cable length. I was also thinking about mounting it to the drivers kick panel since the positive battery cable runs near there. But if I ever have to get behind the panel again, I might have to unmount the switch to remove the panel...
    Thoughts? Ideas? Pictures of your install would be great :-)
    TIA
    -Scott
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Move the battery(ies) to under the observer seat, pushed all the way forward. Mount the switch on the inside wall under the observer seat that is closest to the driver. Preferably, use a mounting board.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • Chexi
      • Apr 2025
      • 2119
      • Austin
      • 2000 SAN
      Check out my album for pictures on my battery - isolator - combiner install. You could simplify it with just a perko switch on your 1 battery, but place and mount them the same.
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
      • Chexi
        • Apr 2025
        • 2119
        • Austin
        • 2000 SAN
        I mean you can use a Perko on your 2 batteries instead of the combiner switch I used.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • h2oski
          • Oct 2010
          • 49
          • Liberty Hill, TX
          Thanks Chexi (same as chexi1?). I'm using the Blue Seas ACR too. I said "perko" because it's a house hold name for a battery switch (like klinex is for tissue). Your pictures confirm what I was thinking. It turns out the 2ga starter to battery run will reach the switch if I mount it where you did. I plan to use 1/0 ga for every thing else. I'm also adding a ProMariner ProSport 12 2 bank battery charger next to the switch and ACR in place of where you mounted the Alpine amp. I plan to mount the batteries side by side like you did, but front to back instead. I found these neat aluminum CNC cut Optima battery trays to mount the batteries. I'll use plastic stand-offs to hold the trays off the carpet incase my wife turns the boat into a submarine. It looks like you used a large "plastic" cutting board to mount the components, good idea! I'll grab one at target or wally world. Unfortuantly, that idea didn't hit me until I drilled two 1/8" holes in that center "wall". Of course the coaming pad with the black fish net didn't cover them either - dumb .
          Did you wire in the SI circuit on the ACR over to the ignition switch? If so, what gauge wire did you use?
          Thank you again!
          • Chexi
            • Apr 2025
            • 2119
            • Austin
            • 2000 SAN
            I did not wire the ACR into the ignition switch. It never really seemed necessary to me.
            I wish I could take credit for the cutting board, but I can't. Got the idea here. Note, my cutting board is not secured down, except by the fact that it slides in between the glove box bump out and the walk-through wall. I was going to secure on one or more of the combing pad bolts, but never needed to. I like being able to pull it out to play with the amp gains or change a fuse, etc. (not that I have to either often). I've had no problems with it unsecured, it is pretty tight and does not move.
            I used 0/1 AWG for all the wiring I added, but kept the electrical from the engine as is and have had no problems.
            I use a Ctek charger with quick connects on each battery. Works very well. A dual bank charger should be very nice for you.
            Bummer about the drilled hole. Wish I had seen your post earlier.
            Yes Chexi and Chexi1 are both me. Forgot my login one day and re-registered.
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
            • Ski Nautique 1
              • Mar 2011
              • 11
              • Houston
              • 1982 SKI NAUTIQUE 2002 PRO AIR 2005 226
              you make the call
              TIA
              -Scott
              Use "00" cable and ou can put them anywhere you want
