winterization article
  • Hollywood
    • Sep 2003
    • 1930
    • WIIL
    In the supplied winterization article "How to properly winterize your boat" by David Williams I noticed a not so helpful tip. In the "Clean, clean, clean your boat" section he says to apply a quality polish to create a protective barrier...blah blah blah. Any detailer knows that this is not the role of polish. Polish kinda actually does the opposite effect on your applied surface. Polish rubs away a layer, revealing that clean, shiney coat. Unless you reseal the surface you just wore away it will be even more seceptable to dirt and fading.
    Basically, polish gives you the nice clean look, but needs to be sealed by a sealer or wax for protection.
  • NautiqueJeff
    A d m i n i s t r a t o r
    • Mar 2002
    • 17154
    • Lake Norman
    • Mooresville, NC
    Hollywood:
    Your post has been noted in the article. Take a look at the article now and you'll see that I have added your information. Thanks for catching that.
    Clean, Clean, Clean Your Boat
    Before putting your boat to bed for the winter, be sure to give it a good cleaning inside and out. If you store your boat with dirt, scum, barnacles and the like on the exterior, these impurities will be even harder to remove in the spring. Once the exterior of your boat is sparkly clean, apply a quality polish to create a protective barrier against dirt and dust.
    Forum member Hollywood has the following response to the above section of this article:
    "In the supplied winterization article "How to properly winterize your boat" by David Williams I noticed a not so helpful tip. In the "Clean, clean, clean your boat" section he says to apply a quality polish to create a protective barrier...blah blah blah. Any detailer knows that this is not the role of polish. Polish kinda actually does the opposite effect on your applied surface. Polish rubs away a layer, revealing that clean, shiney coat. Unless you reseal the surface you just wore away it will be even more seceptable to dirt and fading. Basically, polish gives you the nice clean look, but needs to be sealed by a sealer or wax for protection."
    Another thing that this article fails to mention is that you should disconnect your speedo tubes from the dash and blow the water out before putting your boat away for the winter.
    • skinautique
      • 1749
      • Colorado
      Disconnecting a tube from the dash is too much of a headache. Take an air compressor hose and put the tip perpendicular to the pickup. Be careful not to blow the internal parts but if you do it right, you can blow out the water right there. Just do it a couple of quick bursts and you are set. Also, you can check to make sure that both pickups work.
      • Hollywood
        • Sep 2003
        • 1930
        • WIIL
        speedos
        we no longer have to worry about that on our 88. they've been long gone
        • Onthewater
          • 695
          • Near the cheddar curtain
          Re: speedos
          uhhh, what are you talking about kevin?
          I don\'t care.
          • Hollywood
            • Sep 2003
            • 1930
            • WIIL
            speedos
            our speedos have a mind of their own kurt.
            • M3Fan
              • 1034
              One thing I noticed about this article is the fogging oil procedure seems different than I've ever heard before. The article mentions just spraying it in carb- I assume with the engine off? Typically you'd spray it in with the engine running so it can be distributed evenly through the intake plenum. This is important because you really need to coat the valve stems with the fogging oil and I don't see how you could coat intake and exhaust valves, front and back and stems, by just spraying it in there (with the engine off). Even if you spray each spark plug hole, you won't get the back of the valves/stems. Some may be in the closed position. This portion of the article may be more relavant to 2 stroke outboards, which only have reed valves.
              2000 Ski Nautique GT-40
              2016 SN 200 H5
              www.Fifteenoff.com
              • skinautique
                • 1749
                • Colorado
                M3 Fan,
                spray it in the carb while the engine is running. Those of you with EFI can spray it in the air intake located behind the flame arrestor.
                • M3Fan
                  • 1034
                  Originally posted by skinautique
                  M3 Fan,
                  ...That's what I was saying! The article doesn't mention this while the engine is running. I agree with you completely!
                  2016 SN 200 H5
                  www.Fifteenoff.com
                  • skinautique
                    • 1749
                    • Colorado
                    I didn't read the article and so therefore, I misunderstood what you were saying. :oops:
                    • NCH2oSki
                      • 1159
                      • Maryville, TN
                      • 2005 ski nautique 206 SE
                      I am trying to figure out how to time spraying the fogging oil and run the rv antifreeze at the same time. How long does it take to fog the engine? How much pink antifreeze should I need?
                      Will I need to change my plugs next year after fogging? They have 60 hours on them, but are probably the original. Seems as if I have heard about oil on the sensors is a bad thing for efi...any comments?
                      Thanks for the suggestion with the hose and 5 gallon bucket, it worked great. I used it to warm up my engine for the end of season oil change.
                      Prior Boats:
                      1999 Ski Nautique GT-40
                      www.skiersofknoxville.org
                      • skinautique
                        • 1749
                        • Colorado
                        Use two gallons unless you have a heater or shower. I fog the whole time that I am dumping antifreeze. When the antifreeze is out, I quit fogging.
                        • SGY
                          • 990
                          Fogging oil on Map sensor
                          NCH2oSki, you probably heard the oil on sensor issue from an earlier post from me. I fogged my GT-40 last year by spraying through the intake. PCM says that's a no-no. It's considered a "dry intake". So, how I ask, does one properly "fog" the motor? I guess the solution would be to mix fogging oil (or two stroke oil), gas, and Stabil, all in one and run it through your fuel system into your motor. Thats how the shops do it around here. You then pour a copious amount of Stabil into your tank. At the same time you run antifreeze through your motor. Sounds like you need four hands.
                          Does anyone know where the pickup from the fuel tank starts? Is it on the small external fuel pump below the fuel cannister holding the fuel filter or does the fuel go into the cannister first? I can't tell due to the presence of what I assume are return or circulation lines.
                          • M3Fan
                            • 1034
                            Between fogging the oil through the air intake and mixing all the stuff together like you thought, I would fog REGARDLESS of what PCM says. Esp with the newer fogging sprays that even have a little extension straw on the nozzle. I know people that have fogged like this on EFI engines for YEARS and had no problems.
                            2016 SN 200 H5
                            www.Fifteenoff.com
                            • MarkP
                              • Sep 2003
                              • 155
                              • Rochester Pennsylvania
                              I only fog my cylinders also!! My dealer also said it's a dry intake!!
                              2004 Ski 206 Limited,Midnight Blue and Black,
                              Silver Accents,330 Excalibur,Perfect Pass.
                              Nautiques Rock!! My 2004 206
