Suggestions on Upgraded Alternator GT-40 (high output)
  • fortnox
    • Jun 2010
    • 34
    • 2001 SANTE 210
    Currently Stock 55amp alternator; 2001 Super Air:
    I was wondering what alternators would work in a GT-40 engine. I saw the GT-40 100 amp alternator ugrade on Whitelake Marine.
    Is this the only alternator that would work or would a generic 100 amp alternator work the same? Or could I upgrade it to more?
    Also, how many Amps would be recommended to use with Factory wiring. I was reading that anything over 100amps would be pushing the limits. Has anyone else experienced any problems?
    I have 4 amps (3 JL 300.4's and Audiobahn 700.1) peak power 1600rms, 3 batteries, Onboard charger.
    I am looking for specific recommenations please. If you know where to get it that would be great, or are using an upgraded alternator, please advise
    Thanks,
    Fortnox
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    I use the factory alternator upgrade kit and for me it works perfect. I have all the pics in my photo album.
    You can see what I run for my stereo in my stereo thread.
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      The real issue is the factory wiring must be upgraded to handle the extra amps, and the whitelake kit has a engineered harness that is a direct fit. No worries about sizing wires and guessing lengths its all done for you. Dont be cheap as you would hate to burn your nautique to the ground to save 100 bucks......
      2001 Super Air Nautique
      Python Powered
      100 Amp Alternator
      Dual Batteries
      Many upgrades coming...
      • fortnox
        • Jun 2010
        • 34
        • 2001 SANTE 210
        thanks guys that was helpful! I think I will just go with the nautique upgraded alternator then. Just wanted to get another opinion or two!
        • Ski Nautique 1
          • Mar 2011
          • 11
          • Houston
          • 1982 SKI NAUTIQUE 2002 PRO AIR 2005 226
          Upgrade info
          Thanks,
          Fortnox
          The alt upgrade comes with the all wireing to do everything on your engine, get it from PCM
