Need a new long block
  • Nauty210
    • Mar 2011
    • 4
    • Us
    Hey guys, trying to figure out where I can find the right long block for my 5.7L ex 343 PCM engine. I have friend that has some auto gm long blocks in stock but I'm worried it won't be compatible. Does PCM build the top and bottom end with performance parts? My biggest concern is that I won't have the proper compression ratio 9.4:1 if I use a standard long block. Any suggestions? Does anyone have the long block specs PCM uses? Any help is appreciated!
  • Nauty210
    • Mar 2011
    • 4
    • Us
    Any ideas? Btw, here are my casting numbers if it helps:
    Block: 10243880
    Heads: 10239906
    • AirTool
      • 4049
      • Katy, Texas
      Block: 10243880
      Heads: 10239906
      get a new one here with site discount: David deAndrade sales@whitelake.com
      check with david for rebuilt also. Dealers always have connections.
      exchange here: http://www.jasperengines.com/marine-products.php
