gt40 fuel lines
  • toyota40runner
    • Jun 2007
    • 190
    • Kapaa, HI
    gt40 fuel lines
    i had to move my fuel pump to make my fresh water cooling kit fit and i forgot which fuel line went to which hose barb. there is a big canister and small one. one hose has red tape, one doesnt, if anyone could take a look at theirs and tell me i would be so happy!! thank you
    Boat: 2001 Nautique Super Sport
    \"Dont forget to put the plug in.\"
    http://www.planetnautique.com/index....amp;highlight=
    Another Ballast Install
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    In my old thread you can kind of see that fuel line with the red tape in the 4th picture. Maybe that will help. I'm not by my boat so I can't go check.
    http://www.planetnautique.com/vb3/sh...allast-install.
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
    • east tx skier
      • Apr 2005
      • 1561
      • Tyler, TX
      From talking to my dealer's service tech, the red tape doesn't necessarily have meaning unless you can correlate it with the line on the top of the gas tank. He has seen some return lines marked with red tape and some feed lines marked with red tape. While it's typically the return, that's not always the case with these boats handmade by humans.
      • toyota40runner
        • Jun 2007
        • 190
        • Kapaa, HI
        i figured it out, just hooked them up and the boat wouldnt run, switched them and it would run
          Did you put the red tape hose on the low pressure fuel pump, or on the FCC fitting?
