Changing impeller on 2009 PCM Excalibur
  • heliskier
    • Jun 2008
    • 71
    • Tuscaloosa,Al
    • 2011 Sport Nautique
    I have been told it is very simple on the new engines. Do i need to remove the belt or anything
    or what do I need to watch out for?? I was looking at the motor over the weekend & thought I would get some feed back before I tackled the job.
    2009 Air Nautique 216 Team
    2008 Air Nautique 216
    1999 Sport Nautique
    1996 SNOB
    1985 Ski Nautique 2001
  • AirTool
    • 4049
    • Katy, Texas
    Maybe, just maybe one day I'll put this up as a stand-alone post in the how to:
    15mm or adjustable wrench for the idler pully.
    10mm socket with extension for the pump cover bolts. (see pic)
    1. Take the serp belt off. (If you can't figure out how to do this, stop and take your boat to the dealer.)
    2. Take the three cover bolts off - bolts stay with cover due to tiny o-rings.
    3. Carefully twist the pulley and slightly mis-align the pump as you pull it out and the impeller will come out with it. Otherwise the impeller stays in the cavity.
    4. Change out the four o-rings. One for the cover, three for the bolts. Some oil or soap as lube is handy but not required.
    5. Squirt some dish soap on the impeller and lather it up with a bit of water.
    6. Place the impeller on the shaft.
    7. Then line up the impeller with casing and "top" at the top. Then rotate the pulley in the running direction and the impeller will slip right in.
    8. Snug the three bolts.
    9. Torque to 9 ft-lbs
    10. Put the belt back on.
    11. Get 'er back in the water.
    Disclaimer: this is a guide only. YOU are responsible for your work...not me.
    • Nautiquehunter
      • Jun 2008
      • 2080
      Wow Airtool !
      That is probubly the best how to post I have ever seen. My dog could change the impeller after reading that.
      • Quinner
        • 2246
        • Correct Crafts
        Nice Job Tool!
        I am lmao after reading however, having R&R'd mine at least a dozen times and never thought about using an extension through the pulley like that, always removed the pulley from the pump to access the bolts, probably only takes 30 seconds longer but I will never get those 6 minutes back, LOL.
        • heliskier
          • Jun 2008
          • 71
          • Tuscaloosa,Al
          Thanks for the help. I wanted to make sure before I got started. I hate left over parts.
          1999 Sport Nautique
          1996 SNOB
          • AirTool
            • 4049
            • Katy, Texas
            Originally posted by Quinner View Post
            Nice Job Tool!
            LOL is right. The rub about removing the pulley bolts is, what happens if you drop it down in the bildge? I'm sure you will likely find it but what a PITA. and if you don't find it, those are probably difficult to procure....stainless steel metric allen capscrews!!
            Also, It is easier to get to the pump bolts with a longer extension and lifting the bottom section of the clamshell. I feel sorry for those v-drive folks.
            ALL = please click on to the "star" at the bottom of my post and add to my reputation. Thanks for all the kudos, etc. Maybe next time I'll have my son videograph me and I'll put up a video. This job takes less than 5 minutes which is longer than his attention span
            • CradGen2
              • Aug 2020
              • 1343
              • Horseheads NY
              Nice Airtool, care to do one on changing the fuel filter in the canister?
              • AirTool
                • 4049
                • Katy, Texas
                Thanks and good idea. I'm due for a filter and still would like to look at the pre-filter. only few models have those. Maybe the screw to my filler cap chain is in there
                On the big filter, Let me grab my 3 foot pipe wrench and a cheater bar!!! ....just kidding, mine is the new style with the t-screw.
                • CradGen2
                  • Aug 2020
                  • 1343
                  • Horseheads NY
                  A/T,
                  One more question. Why is the direction of the impeller important. I did mine this weekend and noticed that when I spun the pully as I was putting it back together the fins went in the right direction. doesn't look like it matters which direction the impeller goes in first.
                  • AirTool
                    • 4049
                    • Katy, Texas
                    A/T,
                    The pump only works properly and lasts its lifetime when the fins are in the proper direction. There are previous posts that say the fins will reverse if the impeller is put in backwards. I'd prefer not to stress my fins like that. With a soapy lube, it is probably okay. Note my pic of the belt path, engine rotation, blue masking tape with the sharpied arrow, and comment about turning the pump in the direction of travel.
                    Good work on your part. You probably just saved yourself about 150 big ones. Maybe someone can post the labor charge for an impeller change.
                    • teamenzo
                      • Feb 2010
                      • 48
                      • Seattle/Sammamish
                      Labor I was told by a local MC dealer was an hour, at $135. Not sure what my Nautique dealer cost would be, but I prefer to support anyway.
                      2007 sv 211TE
                      2007 Chaparral 210
                      Seattle WA
                      • iceman991
                        • Jul 2006
                        • 138
                        • 707
                        • 81' ski nautique 20th anniversary edition 05' SANTE 210
                        thanks air tool.....couldn't be more easy with the pics and directions.....ur saving us lots of money buddy!
                        • gride
                          • Jun 2007
                          • 1441
                          • War Eagle
                          • 05' 210 team
                          Does the impeller from nautiqueparts come with the big o ring and 3 smaller ones?
                          • maxxwell
                            • Jul 2010
                            • 147
                            • Houston, TX
                            • 2008 Air Nautique SV211 TE
                            sure does, included in the blister package
                            Gone - 2008 Air Nautique SV-211 Team Ed - Death by Fire
                            • AirTool
                              • 4049
                              • Katy, Texas
                              Gride - maxxwell is correct. Look at the parts picture. The o-rings are shipped sandwiched between the back card and the card shrink wrapped around the impeller. So when you see the impeller package on web sites, you don't see the o-rings.
