Teleflex gauges question
    • Jan 2025
    For those of you who have converted the teleflex gauges to the analogs, I have a few questions.
    1. Was it easy to do? Are they plug and play, or do they come with good and easy to follow directions? Or, is this something best left to a professional?
    2. If one were to add perfect pass, would you recommend putting it in the middle between the two new analog gauges?
    3. Finally, if one adds perfect pass, is it even worth adding the faria gauges?
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    Here is the pdf:
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
      • Jan 2025
      As usual, it's Wake_Fun to the rescue! Thanks man.
        • Jan 2025
        After reading the PDF, it sounds moderately complicated, but nothing that I could not tackle. Thanks again WakeFun.
        I guess adding the gauges will give me a nice visible tach. I can't recall whether you get simultaneous RPM readout on a 4-line Perfect Pass display, but even if one does, it is not as in your face obvious as on these big analog gauges.
        • wake_fun
          • 1330
          • CA
          • 1995 Super Sport
          Welcome
          Photo Album
          Ballast Install 1
          Ballast Install 2
          Amp Install
          PPass Install
          Alternator Install
          • 74green
            • Nov 2009
            • 281
            • Canyon Lake, Texas
            • 2001 Air Nautique
            http://www.planetnautique.com/vb3/sh...ria-Conversion
            Not to bad of an install. Just measure the paddle wheel hole several times before you drill the 2" thru your hull. I used magnets to check location.
            Current: 2001 Air Nautique GT-40
              • Jan 2025
              Good idea on the magnets.
              • wake_fun
                • 1330
                • CA
                • 1995 Super Sport
                Hey Chexi........click on my Perfect Pass Install LINK in my sig
                Photo Album
                Ballast Install 1
                Ballast Install 2
                Amp Install
                PPass Install
                Alternator Install
                • chevyspy
                  • Feb 2011
                  • 13
                  • USA
                  Originally posted by wake_fun View Post
                  Here is the pdf:
                  I wonder if Correct Craft still honors the pricing outlined in this sheet?
                  • bchesley
                    • Feb 2006
                    • 1252
                    • Tyler, Texas
                    Chexi,
                    Its easy to do. I did mine about 3 months ago in about an hour. Does your SAN have perfect pass?
                    2001 Super Air Nautique
                    Python Powered
                    100 Amp Alternator
                    Dual Batteries
                    Many upgrades coming...
                      • Jan 2025
                      No, it does not have perfect pass... yet. I'm going to rip my PP Wakeboard Pro out of my 96 Tige and put it in the SAN. I found a place that sells a GPS module that integrates with PP and will allow me not to have to drill the hole. I ordered the Faria kit for no PP just in case, plus the cable that comes with the "with PP" kit. Either way, I should be covered. I won't get the water temp feature without the paddlewheel, but I'm going to install a separate temp/depth sounder system anyway.
                      One of these days, we are going to have to meet Brad. Every time I come to Ski N Sports, it seems we just miss each other. I really would like to check out your Python.
                        • Jan 2025
                        Thanks Wake_fun.
                        • east tx skier
                          • Apr 2005
                          • 1561
                          • Tyler, TX
                          I was over there on Saturday and finally got to see Brad's Python. I asked him why it was that the guys who had this engine never posted pictures of it on the web. Suffice it to say, it looks nice.
                          • ers906
                            • Feb 2010
                            • 921
                            • Phoenix AZ
                            It is extremely easy. Took me less than 30 minutes, however since I have the GPS based perfect pass I only installed the tach with the hourmeter. I used the other 5" hole to place a remote for my stereo (it has all the info from my iPod on the screen). Works great. The GPS setting on the perfect pass is plenty for me as far knowing the speed.
                            Eric, Phoenix AZ
                            G23 550 hp (finally here)
                            2002 Super Air
                            • bchesley
                              • Feb 2006
                              • 1252
                              • Tyler, Texas
                              Chexi,
                              We definately need a North East Texas get together. I always love checking other peoples boats out, and I of course would love to show off my python....
                              Brad
                              Python Powered
                              100 Amp Alternator
                              Dual Batteries
