A novel Heater fix question
  • Chexi
    • Jan 2025
    • 2119
    • Austin
    • 2000 SAN
    So my heater went last year. I purchased the Ford LTD heater, which is very close, but the exit and entry pipes are a little off, requiring a little Dremel magic. This I get. What I need help with is locating replacement insulation to go around the heater. The standard stuff I found at Lowes is too thick. I suppose I could shave it down, but I'd rather have an even surface, as there is not that much clearance. Any ideas where to find a suitable (and thin) insulator (I think it's just for shock absorbtion)?
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
  • johnboyy7
    • Oct 2009
    • 409
    • houston
    Mine came with the heater from oreileys.
    04 SANTE 210
    89 SPORT
    • Chexi
      • Jan 2025
      • 2119
      • Austin
      • 2000 SAN
      Did the one you got from O'Reilly's also fit a bit off, or was it a perfect fit? If it's a perfect fit (meaning the intake out outflow lines lined up perfectly), maybe I'll just buy another one and consider the first one I bought a sunk cost.
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
        Just cut the foam insulation to fit, or get the O'Reilly's core. Your choice.
