Where do I find a 160 degree? Went to orally and they only carry 195.
Ha Ha! Jeff can we have a default reply to any thread that asks "where can I find this part" that says White Lake Marine? While this may be true. Some people may want to run and pick up a part today. Not trying to be a smart a, just think is funny.
Originally posted by johnboyy7 View PostWhere do I find a 160 degree? Went to orally and they only carry 195.
Stant 13006 (economy)
Stant 45356 (premium)
Gates 33006
I love White Lake. David won't mind if you stop by your local auto dealer and pick up a 4 dollar stat.
Please click on the impeller-looking star below and add to my reputation.
Johnboy,
I recommend using a PCM thermostat that can be picked up at any nautique dealer for a reasonable price. I am a stickler for using OEM on a 30+ thousand dollar boat. It's just silly to me to squabble over saving 5 - 10 dollars that can cost you so much more if it sticks and you over heat. My two cents...2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
Originally posted by bchesley View PostJohnboy,
I recommend using a PCM thermostat that can be picked up at any nautique dealer for a reasonable price. I am a stickler for using OEM on a 30+ thousand dollar boat. ...
The bigger question is, Why do you want a 160 degree stat in the first place? It is not OEM.
Originally posted by maxpower220 View PostSo the thermostat in your $50K+ tow rig isn't as (or more) reliable than the same one with a PCM stamp on it?
?? Come again ?
160* for raw water cooled,
170* for closed cooling
143* for older carbed boatsLast edited by WakeSlayer; 03-23-2011, 01:25 PM.the WakeSlayer
1968 Correct Craft Mustang
To answer the question, no, I use Cummins OEM t-stats too. Maybe I am weird, but the tolerances in OEM and aftermarket are not the same so I choose OEM always. Would you use bailing wire to hook up a stereo? It will work I am sure of it.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
This thread has gone crazy.
The stant cap is just fine...especially for fresh water or closed cooling. Note the last AC Delco stat and cap I bought were made in India. Go GM !
For an open salt water system, (YIKES!) I'd try to find an all brass unit but wouldn't lose sleep over using a stainless steel model and changing it every few years.
