Water in the bow
  • johnboyy7
    • Oct 2009
    • 409
    • houston
    Water in the bow
    I can't figure out where it is coming from? I have plugged the drain. NO water is coming over the bow.
    I have put a towel down across the carpet under the cushion. It appears that the water is coming from under the walk way but I have no idea what ties into there or how water could get to there from the underneath.
    Thoughts???
    The vent on the port side below the windshield, where does this go?
    Boat is an 04 210.
    04 SANTE 210
    89 SPORT
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    I think that vent is the glove box drain. There's a small grate under the bow cushion that leads to the bilge.
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      A friend of mine's 04 SV211 did this. A fitting on his ballast tank had cracked. May be worth inspecting. Perhaps you can get a mirror or something in a position that you can see them. He did not realize this was the problem until he was installing a bag system.
      the WakeSlayer
      1968 Correct Craft Mustang
      • jward
        • Feb 2008
        • 620
        • Sweet Home Alabama
        • 03 SANTE 04 SANTE
        Could be coming through the rub rail. How much water are we talking about?
        • johnboyy7
          • Oct 2009
          • 409
          • houston
          Just enough to soak a towel or if no towel get the carpet very wet.
          Slayer.,.. Are there any tank fitting other than the ones I can see?
          Gride... That drain is plugged under the cushion in the very front.
          04 SANTE 210
          89 SPORT
          • xrichard
            • Aug 2008
            • 667
            • El Dorado Hills
            • 2023 G23
            I had a similar issue...towels/clothes getting wet under the observers seat, but not huge amounts of water and it was very difficult to know where it was coming from. I had the rubrail pulled and and the hull/deck seam sealed under warranty a couple of months ago. So far, no problems....I'm keeping my fingers crossed.
            Previous boats:
            2015 G23
            2008 SAN 210
            2002 XStar
            1995 Sport Nautique
            • xrichard
              • Aug 2008
              • 667
              • El Dorado Hills
              • 2023 G23
              The other day I had some water under the observer seat. Obviously, pretty frustrating given that I had the rubrail sealed (warranty).
              A friend and I spent a bit of time looking for the source and determined it was coming in through the docking lights. It was difficult to determine this because the water was coming in and traveling under the carpet down to the lip of the chine on the inside of the hull. It then traveled aft, hidden under the carpet, until it soaked through the carpet under the observer seat. We couldn't tell the source of the water visually--we found it by pressing the carpet tight to the hull and trying to follow the water path by feel.
              I pulled the docking lights and it was obvious that water could enter at this point because the gasket is not thick enough to create a seal between the curved hull and the flat light assembly. I set the lights in some bedding compound and hope my water mystery is finally solved.
              I'm guessing any Nautique with docking lights is susceptible to this problem if you have a bunch of weight in the bow....passengers or ballast. The day the water appeared (after months of no problem) was a day I had extra people in the boat and one of the larger guys spent the day riding in the bow.
              Hopefully this will help a few other frustrated souls!
              Previous boats:
              2015 G23
              2008 SAN 210
              2002 XStar
              1995 Sport Nautique
