So is it better to use 4200 or 5200 on a 1" Mushroom thru-hull fitting?
I would think 4200 so its not Permanent... Thoughts?
I am also installing a Protection plate around the rudder to prevent the prop wash from eating away the gel coat around the rudder.... it screws on with 6 screws, but should I also use some 4200 there too?
