2001 san ballast
  • hyparks
    • Feb 2011
    • 302
    • Brownhills, United Kingdom
    • 2001 Super Air 210
    2001 san ballast
    Hi. Can anyone tell me exactly how my ballast works? It's got the sea **** and there is two knobs under the stereo. Also a fill and empty button on the keypad.
    Reason i ask is because I recently brought my boat and I opened the sea ****. Opened the knobs (counter clockwise) and when driving along the gauges never moved and it appeared to have no water in the tanks. The pumps were not working either. I have since replaced the pumps but not had chance to test yet.
    Any advice would be much appreciated.
    Thanks
    Sent from my Desire HD using Tapatalk
    Current
    2001 SAN 210, GT40
    Previous
    1994 Mastercraft Pro Star 190
    • Jan 2025
    Check to make sure the main ball valve on the thru-hull is open (lever should be in line with the pipe, not at a 90 degree angle). Also you need to be moving about 20mph to fill without pumps. I never know which way is open on the handles on these old systems, so just try both. It may take a minute or two for the gauges to register anything. They are not terribly accurate.
    Also, this is the part where wakefun will chime in and advise you to rip those hard tanks out and put in a bag system, preferably using impeller pumps, and that would be good advice.
    • hyparks
      • Feb 2011
      • 302
      Hi thanks for reply. As I live in the UK and petrol prices are ridiculous, the boat runs on lpg and petrol. So have got a 60 litre lpg tank either side of the engine situated ontop of the ballast tanks. So it might not be an option for me to change to bags unless I had some sort of frame built to sit the lpg tanks on.
      Thanks
      Current
      2001 SAN 210, GT40
      Previous
      • jchamlin
        • Jun 2004
        • 171
        • Charlotte, NC
        The two knobs under the stereo are a little counter intuitive...at least to me. I have a 2000 Air. When you unscrew the valves, it closes the system, so it's more / very difficult for water to get into the ballast. When you screw in / tighten the knobs, it opens the system so it's easy to get water in there.
        So screw in the knobs and make sure the valve in the engine compartment is open (in-line) with the pipe and give it a try. You need to be moving to prime the pumps but once you get on plane, the ballast should start filling up regardless of whether the pumps are working.
        If everything is working, you'll hear a gurgling noise coming from the air line near the driver seat, assuming you have all the knobs and levers in the right position. I'm also assuming the 2000 and 2001 are the system setup.
        Clear as mud?
        2000 Air Nautique
          • Jan 2025
          Thanks
          I would be a little concerned about filling the LPG tanks on top of the ballast tanks unless there some additional support there. The tanks are not that strong and could crack under the weight.
          • hyparks
            • Feb 2011
            • 302
            I hope it is all ok as it was a Nautique main dealer who fitted the lpg system for me. I believe it is boarded across the ballast tanks and the lpg is ontop of that. Also extra weight means more ballast. Lol
            Current
            2001 SAN 210, GT40
            Previous
            • hyparks
              • Feb 2011
              • 302
              Thanks for your help guys. Will try at weekend.
              Current
              2001 SAN 210, GT40
              Previous
                You have two pumps, in the bilge, and the out of both pumps is hosed to push into out port on the other pump. The in port on the fill pump connects to the through hull fitting. The in port in the drain pump connects to a "T", and then a hose goes to the bottom of both the port, and starboard tanks. Turning on the fill pump pushes water through the drain pump, and turning on the drain pump pushes water through the fill pump.
                The valves by the helm control vents on the top of the tanks. If you do not open the air valve, nothing happens, the fill pump cannot force water into the tank against air pressure, nor can the drain pump suck water out against the vacuum that forms in the tanks.
                If you leave the valves open, water will get forced into the tanks when you are moving forward, but when you. stop moving, the water will siphon back out of the tanks. You do not need the pumps to fill, or drain the tanks, but using them speeds up the process.
                If you close the through hull valve, you stop water flow. The tanks stay full, or drained.
                If you close the vent valves only, the tanks will fill slightly, or drain slightly, but not much.
                • hyparks
                  • Feb 2011
                  • 302
                  That's great. Thanks very much. Now I understand how they work. Cant wait to get it set up properly now.
                  Thanks again
                  Current
                  2001 SAN 210, GT40
                  Previous
                  • hyparks
                    • Feb 2011
                    • 302
                    Is there any way I can test my ballast gauges as they appear to not be working. Can I short something to see if the needle moves etc?
                    Thanks
                    Current
                    2001 SAN 210, GT40
                    Previous
                    • ers906
                      • Feb 2010
                      • 921
                      • Phoenix AZ
                      I would recommend one of those intake things that look likle a plunger and has a hose attatchment. Typically used for the intake for the engine to run while you are out of the water. For the life of me cannot remember what they are called, but I have used them to work on the ballast system.
                      Eric, Phoenix AZ
                      G23 550 hp (finally here)
                      2002 Super Air
                      • hyparks
                        • Feb 2011
                        • 302
                        Fake a lake?
                        Current
                        2001 SAN 210, GT40
                        Previous
                        • ers906
                          • Feb 2010
                          • 921
                          • Phoenix AZ
                          Exactly. Couldnt remember the name for the life of me
                          Eric, Phoenix AZ
                          2002 Super Air
                          • hyparks
                            • Feb 2011
                            • 302
                            Been playing around with the ballast on the lake today and im not sure if its working correctly. i started to fill the tanks and eventually had water trickling out of the hole on the starboard side by the driver seat. It was only trickling out though and not spraying. Is this correct?
                            I also noticed that the tanks had actually expanded. In previous posts i had stated i have an lpg tank either side of the engine ontop of the tanks. These had raised up so the ballast tank had definately expanded. Is this normal or am i getting an air lock?
                            Also i dont seem to be able to empty the tanks. I hear the pump running but no water is coming out of the hull. Also the only pumps i can see and hear are the 2 white ballast pumps on the port side of the engine at the bottom. Is one fill and one empty or are they both fill pumps and theres another pump for empty?
                            Also do both bilge pumps pump out of the same hole of the hull?
                            Sorry theres alot of questions.
                            Thanks guys!
                            Current
                            2001 SAN 210, GT40
                            Previous
                              • Jan 2025
                              There only 2 pumps for the entire system. One is fill and the other is empty. You have to use them in conjunction with the vent switches. To fill or empty you need the vent switches open. Close them whenever you want things to stay as they are. Water cannot fill or empty with them closed.
                              If you saw a trickle, there is no air block. To should be able to empty simply by opening the vent switches. You don't even need the empty pump. In fact you Don't really need the fill either. They just make filling and emptying go faster. Note, to fill you need to be moving around 20 moh and to empty you need to be at rest.
