i am needing to replace the carpet on my trailer. does anyone know of a good place to buy it and what kind is it.. thanks........
Replacing trailer carpet
Tags: None
Www.nautiqueparts.com. Pn discount available. Check discount thread for code.Now
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
In case White Lake does not have it or is not convenient to your locale:
Replaced the bunks on my lift this winter, picked up Black indoor/outdoor carpet from the local Menards (Home Depot/Lowes) store, exact match to the bunk lift carpet and looks to be the same stuff on the bunks of my trailer as well. IIRC it was about $0.48 sq ft.
Trailer carpet
Ditto on Lowes, got some indoor/outdoor carpet (black/gray) from them and it was a pretty close match and worked well at a fraction of the cost of going through any "marine" type store. On two years now with no real wear showing. Have enough to do trailer probably 3 more times if and when needed.2004 196 LE Black/Grey
330HP Excalibur Water Churner
2002 Grey F150 Harley
475+HP Supercharged Tire Burner
If you don't like the color/quality available from the big stores, check a local upholstery shop. I was able to get some very nice marine carpet left over by the yard for some in the cockpit projects. Would probably have them order me some if I needed enough for the bunks if the price was right.2005 SV-211
When I was redoing the carpet in my boat, i looked at everything i could find to make a decision. The stuff at Lowes / Home Depot was the thinnest stuff I found and I personally dont think it would hold up over time especially on trailer bunks. I ended up ordering from boatcarpetbuys.com becasue they had a higher quality product. I would give them or another distributor a call, or an upholstry place like was mentioned, and see if they have some narrow strips that have been cut off that you can use. You can probably get some 8 inch by 20 foot scraps pretty cheap from some of these places.
give california trailer works a call. I just re did my trailer, bunks, crash pads, fenders, v blocks and the carpet is pretty nice.
You have a Nautique right? Lowes and Home depot are not what you should be considering. Maybe if you put an alluminum fishing boat on that trailer. California Trailer works is where I got my bunk carpet. It was Nautique Oem Quality. You will need really good stainless staples and alot of them. The carpet also stretched a pretty good amount so be patient, and having an extra hand to help tug is advised.
Lowes Carpet
I used the Lowe's carpet on the trailer platforms, but agree that it wouldn't probably be the best choice for the bunks.1993 Sport Nautique
- New Interior - Copycat Covers
- Ramlin Trailer overhaul
- Buff and polish oxidated gel coat
- Exhaust repair
- Holley rebuild
Previous: 1980 Mastercraft - Lake Lanier. GA
