I am continuing my month long yearly duty of the oiling of my teak swim platform and was wondering, do you continue to oil it until no more absorbs, or are 4-5 spray on coats enough. The color has changed etc for the last few coats I sprayed on this year, but oil is still being absorbed over the course of the 12 hours between spraying and checking on it. Any thoughts? ideas? pearls of wisdom?
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
Question re: oiling teak swim platform
Eric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
1994 Sun Tracker Party Barge 115 hpTags: None
This is how we do ours;
http://www.boatus.com/boattech/casey/29.htm
It will stay dark, rich looking most of the year. Plus, it will not get oily or greasying; IE slipping and busting your hiney
When I'm starting from scratch, I usually do two coats. I start by sanding with 120 grit, sweep off the dust, rub the first coat on by hand (with the teak oil in an old windex bottle), wait 10 minutes and wipe off the excess. Let it dry completely (the sun and several days is helpful here). Hit it lightly with some 0-grade steel wool, and reoil. Wipe excess. Dry. This lasts me the whole season.
When I'm not starting from scratch, I just hit it with the steel wool and put on one coat. My platform is functional. Not a show piece. Plenty of skis put on on it. But I still think it looks pretty good.
Brass would probably be a good idea. I'm pretty meticulous about dusting off the platform before oiling. I have never had a problem with rusty bits or stains from using the steel wool on it.1998 Ski Nautique (Red/Silver Cloud), GT-40, Perfect Pass Stargazer 8.0z (Zbox), Acme #422, Tunable Rudder.
- Feb 2010
- 921
- Phoenix AZ
"Spray on teak oil" = normal oil placed in a spray bottle easier and cleaner for me I guessEric, Phoenix AZ
2002 Super Air
I wipe on the teak oil liberally, with a small rag and let it soak it up.. I have 6-8 coats on this one since I bought it last fall and its still thirsty.. but getting there... it was neglected by previous owner I guess. starting to hold the color and wet look.... its not a show piece, but looks nice. I doubt you can go wrong with this method.. spray bottle with teak oil in it would be easier, just watch the overspray and do it off the boat to avoid getting it all over the back end with overspray.na
