I searched, but I can't find what I need. I am trying to change the transmission oil and v-drive oil on a boat I bought a few months ago. It is a 2002 Super Sport with the GT 40. It has the Walter v-drive and the PCM 40 transmission with a 1.0/1.0 ratio. I rigged up a pump with 1/4" outer diameter copped tubing to suck the oil out. When I did the tranny, I got 1 quart out. The engine was cold and the boat was level. The copper tube went in as far as the dipstick does, but no more. When I did the v-drive, I got out about 1/2 quart, which was also done through the dipstick hole.
How much oil are you guys getting out of them?
Also, has anyone followed the procedure in the manual to change the v-drive oil? (drain plug, then disconnecting the oil hose and cleaning the strainer) Necessary?
David
David
