Added rudder plate and new stuffing.
  • Super_sport
    • Mar 2011
    • 134
    • Wisconsin
    I added a gel coat guard/rudder plate to my 95 Super Sport. While I was down there I also replaced the Rudder Packing (3/16") teflon type and polished the prop and rudder to make it look nice.
    Here is a link to my album photos on this project. Hope it helps someone.
    Pictures
    na
  • horkn
    • Aug 2007
    • 270
    • WI
    nice step by step pics!
    I'll have to drop my rudder to replace my strut bushing this spring, so the packing pics are good reference. Unfortunately I need to go further than that by taking the drive shaft out and do that packing too.
    • TRBenj
      • 1681
      • NWCT
      Tom, you dont really think you need to pull the shaft to replace the packing, do you?
      1990 Ski Nautique
      NWCT
      • SquamInboards
        • Sep 2005
        • 397
        • Squam Lake, NH
        • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
        Has to drop shaft to replace strut bushing is what I think he means.
        How 'bout a little reverse action...
        • obd666
          • Feb 2010
          • 793
          • Bostian Heights, NC
          • 03 SANTE
          nice pictorial ... each step by step maintenance item that we document on here with pics makes it so much easier in the future
          2003 SANTE - "OG 210"
          • Super_sport
            • Mar 2011
            • 134
            • Wisconsin
            Thank guys. I pulled the rudder out to add the plate, but the rudder would have fallen out anyway (which it did) when I loosened the top nut and pinch bolt.. Oops... learn from my mistakes. But it was nice to be able to pull the nut off completely, pull packing and polish it up a bit anyway. Now I hope it went together correctly and hold water! I will have to take a peek as soon as the rear end hits water! But plan to order extra packing if you do this, they said 12" of 3/16" should have done it.. but it needed more than that, so I am glad I ordered extra... I had only a little left over from 24".!
            na
            • wake_fun
              • 1330
              • CA
              • 1995 Super Sport
              Looks good!
              Photo Album
              Ballast Install 1
              Ballast Install 2
              Amp Install
              PPass Install
              Alternator Install
              • AirTool
                • 4049
                • Katy, Texas
                is that packing nut really only hand tight?
                like as tight as you can get it by hand?
                will you come back in a few months and check it?
                • horkn
                  • Aug 2007
                  • 270
                  • WI
                  No, I know you don't need to do that to replace the packing, but you do to change the strut bushing. My packing for the DS is fine, but since I have to change the strut bushing I might as well upgrade to the gore tex packing.
                  I re read what I wrote on my earlier post again, and it's correct.
                  • Super_sport
                    • Mar 2011
                    • 134
                    • Wisconsin
                    I did read somewhere to tighten the packing nut on the rudder shaft as tight as you can by hand first... then take a wrench and add about 1/4 -1/2 turn additional. Then when you put in the water the first time, before it leaves the trailer I suggest, to check the seal. If it leaks some, then retighten with wrench another 1/4 turn as needed. But you do not want to overtighten. Some else who has done this before can chime in any time.
                    na
                    • wakeboardjoe
                      • Apr 2011
                      • 63
                      • Texas
                      Hi All,
                      Could not open the pics.. =( Have a 94 that I need help with. Any way you could send me a link? wakeboardjoe@gmail.com
                      Thanks!!!!
                      • Super_sport
                        • Mar 2011
                        • 134
                        • Wisconsin
                        Sorry, the link was broken. Just click on the link in my signature. It will work.
                        na
                        • Super_sport
                          • Mar 2011
                          • 134
                          • Wisconsin
                          Here is the new link.. sorry... I made some changes to the photobucket site and that broke the link.
                          Rudder Packing install
                          na
                          • wakeboardjoe
                            • Apr 2011
                            • 63
                            • Texas
                            Thanks!!
                            • Erik03
                              • Sep 2011
                              • 9
                              • Chico, CA
                              • 2003 super air nautique limited addition
                              Great pics & step by step. Thanks!
