Does anyone know which impeller I need for my 2004 SAN? I was planning on ordering one but am not sure which is the right one. I have the Excalibur engine. Anything difficult about this installation? Anything else you recommend I replace while I'm doing this?
well the search function is great for starters, but i understand not wanting to go through all the posts. i have an 05 excalibur and it uses a serpentine impeller from nautiqueparts.com simple install. search "impeller", and find one of the many threads with airtool's pics of install and tools needed. oil change, v drive and trans fluids, fuel filter, plugs. depends on when these were last done, but...
With v-belts
http://www.nautiqueparts.com/impelle...ltengines.aspx
With serp belt
http://www.nautiqueparts.com/pcmimpe...neengines.aspx
Tell us which belt you have and I'll point you to some critical posts on labor.
I am no expert, but I think you will find that PCM changed to Serpentine belts in the 2005 model year. I can change the impellor in my 05 in about 5 minutes.
If you have a serp belted engine - 15mm spanner drops the serp belt, 10mm socket does the 3 bolts to remove the body of the water pump. Change the impellor & o-rings & put it back together.
I've got the serp belt
Thanks for your help: I've got the serp belt type.
With serp belt
