Alternator Quick Question
  • nmitch05
    • Jan 2009
    • 4
    • Fort Smith, AR
    I have a 2001 SAN that I am currently doing spring cleaning to and maintenance. I removed the alternator to check the bearing and it is still good. While I knew better, I assumed the two smaller connections were different sizes so that I did not need to mark or remember which wire went where.....Unfortunately my memory has dissipated! I know where the large wire goes, but the other two wires are the question. Can anyone help?
    Thanks in advance!
    What engine do you have?
    • nmitch05
      • Jan 2009
      • 4
      • Fort Smith, AR
      I have the Ford 5.8.
      • scuff97
        • Sep 2010
        • 52
        • 1992 sport nautique 2007 SV-211
        This should be a Mando alternator. The small green wire should go to the terminal marked exc and the black wire to the alternator case terminal marked E
        • nmitch05
          • Jan 2009
          • 4
          • Fort Smith, AR
          Thanks!
