rust removal with removing paint
  • clubmyke
    • Sep 2004
    • 414
    • so cal
    can someone suggest what to use to remove rust without removing the the paint ?
    i have to touch up an area on the trailer where i had a bracket welded on.
    thanks,
    mike
  • TylerO
    • Oct 2004
    • 211
    RE: rust removal with removing paint
    Naval Jelly works well for me. Just don't leave it on too long.
    • mrese
      • 67
      You can try a product called "Corrosion X".
      http://www.corrosionx.com/
      It comes in a marine grade but the heavy duty will work for the trailer. Spray it on and let it soak for a while and then scrub with a "Green Pad." It won't remove the paint and is great at stopping / preventing rust.
      • clubmyke
        • Sep 2004
        • 414
        • so cal
        thanks !!!
