Bad day today. I am hoping it is the starter that blew (I have one one order from Nautiqueparts) but just in case I was wondering if anyone has had to replace a flywheel on a 330 hp PCM excalibur Vortec made by GM. Would I have to pull the whole block? once again, hoping it is only the starter but preparing myself for the worse.
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
Flywheel replacement on a GM 330 hp PCM Excalibur
Eric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
1994 Sun Tracker Party Barge 115 hpTags: None
In my experience with gm vehicles, you will definitely have to separate the engine from the tranny to replace the flywheel. Is the starter just spinning and grinding and not engaging the flywheel? Hopefully the starter is just not engaging fully and the flywheel is not damaged. Good luck.2005 SV-211
- Feb 2010
- 921
- Phoenix AZ
Just pulled the starter and looked at the flywheel as a friend turned the belt drive. No damage, no need to pull the engine thankfully. Just replacing the starter now, changing the oil and hopefully she purrsEric, Phoenix AZ
2002 Super Air
Don't throw away your old starter. You should have a quality rebuilder around there somewhere. I have had trouble replacing starters because of the machining differences between motors, having to add shims, etc. The original one would at least be a great backup. Congrats on the good news.2005 SV-211
