Flush Pro Alternative
  • BrennanK
    • Feb 2009
    • 348
    • Hopkins, MN
    I am looking to make my own version of the Flush Pro. I want to make a permanent flushing alternative so I don't need to remove the hose each time I plan to run the boat outside the lake. Here is my mock up.
    What do you think?
    For a 1997 Ski Nautique by the way.
    1997 Ski Nautique
  • johnboyy7
    • Oct 2009
    • 409
    • houston
    Looks good. Do you think there is a need to block off the intake during flushing?
    04 SANTE 210
    89 SPORT
    • Nordicron
      • Sep 2009
      • 557
      • Madison, WI
      just get a spare strainer screen cup.
      I just got a spare strainer screen cup and drilled a hole in it and screwed in a hose barb. When I need to run in the driveway take out the original and put in the modified one and attach the hose. I don't need to block my intake, works fine.
      • BrennanK
        • Feb 2009
        • 348
        • Hopkins, MN
        That might be a good idea. Just so there is no lack of flow / pressure.
        That would also eliminate a lot of the "plumbing"
        I have a hose Y pipe in the image. I would try and get a more substantial one for the actual project.
        Here is the modified plan.
        1997 Ski Nautique
        • ski4evr
          • May 2010
          • 613
          • Bowling Green, KY
          • 2005 SV 211
          The guys I bought mine from used this method to winterize also. They had a medium tub with a 12v pump in it. Replaced the strainer, closed the RW intake valve, and turned on the pump. The tub was placed under the exhaust and after the blue stuff started coming out, the engine was started and ran until operating temperature was reached. I stored mine inside this winter, so I didn't winterize, but that seemed to be a very painless way to do it.
          2005 SV-211
          • Chexi
            • Jan 2025
            • 2119
            • Austin
            • 2000 SAN
            If you use your design, use real engine hose, not the stuff in your picture.
            I like the strainer with hole and hose barb idea.
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
            • 91xl
              • Nov 2010
              • 37
              • Bainbridge Ga
              • 1991 nautique excel 1986 ski supreme-sold for nautique
              use a similar set up to the first diagram i have a perko water inlet fitting for the water hose that i mounted through a existing hole in the hull. works great and as long as the engine speed is not to high the lift pump will pull in what it needs and the excess will go out the pick up
              • BrennanK
                • Feb 2009
                • 348
                • Hopkins, MN
                I finished my little project. I decided to go with a non-permanent install. I used DanialC's idea and made something very similar. I like it better than anything else, I have way more control over what is happening and is easy to flush with anti-freeze also.
                Here is an image of it at work.
                1997 Ski Nautique
