Which wax do you use?
  • etang789
    • May 2009
    • 155
    • Hong Kong
    • 2017 Super Air Nautique G23
    I see many ppl suggesting Collinite's No. 885 Special Heavy Duty Fleetwax on other websites...
    I do use Collinite's No. 915 Marque D'Elegance for my cars.
    2017 Super Air Nautique G23 Coastal Edition
    Crusader H6 Coastal Direct Injection 6.2L
    2010 Super Air Nautique 210TE Coastal Edition
    Crusader 6.0L ZR-409
  • lilet
    • Apr 2011
    • 39
    • greece
    • Nautique 200 CB Nautique 196
    If I keep my boat during all summer in the water is the wax enough or I have to put chemicals on my hull?
    • pzthk6
      • Mar 2008
      • 68
      • St Cloud, FL
      • 2014 SAN 210 2007 SANTE 220 1989 Centurion Barefoot Warrior Comp 1991 Concept 21' CC
      Leaving a boat in the water
      Leaving your boat in the water for an extended period of time is one of the worst things you can do for a boat. Under a microscope gel coat is porous, thus allowing water molecules to enter and hopefully leave. Older gels had a much more porous structure thus more water travel. Newer gels are have a smaller structure which reduces the ability of water to leave if it has entered. Over time and especially if your area sees large temperature swings (nothern climates), you will end up with blisters. Adding to the potential of blisters is the use of a pressure washer and hull cleaners that contain an acid (very bad). If you are stubborn and want to leave your boat in the water, paint the bottom.
      Best advice, you spent the money on a top of the line boat, GET A LIFT.
      • NautiDave07
        • Mar 2008
        • 333
        • Louisville KY
        • 00 SAN210 07 236 TE
        I use Meguires Flagship premium marine wax. It works great easy on easy off.
        00 SAN 210 (previous boat)
        07 236 te sold
        • mf01
          • Jun 2005
          • 515
          • Austin, TX
          I use Zaino All in one. It's easy and lasts longer than Wax.
          Previous:
          2011 Super Air Nautique 210
          1994 Sport Nautique
          • core-rider
            • 1350
            • Huntsville, AL
            • 2003 Black SANTE
            +1 for Meguire's Flagship wax. I use 3M products for cutting/polishing, then add a good coat of Meguire's wax to protect.
            Jason
            All black 2003 SANTE
            -- Southern Fried --
            • ffmedic74
              • 835
              • Lexington, KY
              I am a Collinite fan.
              • h2ohangtime
                • Aug 2009
                • 92
                • Frisco, TX
                • 2002 Super Air Nautique
                +1 more for Meguiar's Flagship. Great product.
                • MARK-S
                  • 764
                  • SE MINN
                  • 1978 Ski Tique 1996 196 2001, 2002, 2003, 2004,2005,2006,2007,2008 196s Best boats made
                  Nufinish
                  Since 2001
                  Life long Nautique guy
                  Will ski anytime.
                  \"SON WATERSPORTS ROCKS\"
                  • DJH
                    • Jan 2011
                    • 119
                    • Overland Park, KS
                    • 2011 SANTE 230 Coastal Edition - April 2011 to now 2006 Ski Nautique 196 Limited - February 2007 to March 2011
                    +1 for Meguire's Flagship wax. I've also had good luck with their vinyl protectant... a littly shiny at first but quickly absorbs and kept the vinyl in my 06 in great shape...
                    Derald
                    2011 SANTE 230 CE (April 2011 - now)
                    2006 SN 196 LE (February 2007 - March 2011)
                    • obd666
                      • Feb 2010
                      • 793
                      • Bostian Heights, NC
                      • 03 SANTE
                      another +1 for Meguire's Flagship, is great stuff
                      2003 SANTE - "OG 210"
                      • trambletf
                        • Nov 2010
                        • 60
                        • Hickory, NC
                        • 2003 sante 210 1996 sport
                        again +1 for meguires wax
                        • actman
                          • Dec 2009
                          • 166
                          • Ontario Canada
                          • SN 200 OB many 196's
                          what I used
                          Last year I used Collinte's Fleetwax on the bottom and sides of my new boat.
                          I found alot of good posts on this product. I spoke to the manufacture and they recommend doing
                          a small area at a time. While I did not listen very well. Once that stuff drys it is very hard to get off.
                          They do make another wax that is easier to remove but will not last as long. For my new boat this
                          year Im going with Meguire's Flagship wax. They make a great product and I always use there vinyl/rubber
                          cleaner conditioner 57 on the seats. I
                          f you don't have a boat lift then I feel you will find alot of differences in the types of waxes. However with with a boat lift any good quality wax will do a great job and last.
