So I just pulled my 216 out of storage. Everything was working great when it was put away in fall, no issues, and now the RPM and the engine temp does not work. Anyone had this problem and have some suggestions of what or where to check. Thanks
It's pretty easy to check the Faria Gateway box connections so I would start there, on my 206 it's in the trunk behind a black plastic cover, you will want to detach it and carefully flip it over, all the connections are on the bottom side, if you have pitot hookups those may need to be detached so you can rotate it enough to see the bottom. Ensure everything is securely plugged in, every plug is unique so you know where to insert them in the event one has dislodged.
If you start having other dash/gauge issues your circuit board in the Faria may have gotten wet/moisture and could be toast.
Good Luck
