I spoke to a few shops and everyone said the same thing. If the bearings are not exposing any copper color, or damaged, then leave them be. Thank god for one piece of good news. After futher review I have zero confidence I would have reached the bearings to where they needed to go be reaching up the oil tank around the crank and pistons.
Mr Bobolina (love that name),
I changed the camshaft in my old hotrod (big block with solid lifters) three times without changing cam bearings. Like you said, no brass, no problem. The pressure and or lack of proper lubricant will eat the lobes. The cam bearings shouldn't have been exposed to the same wear as the lobes of the cam. Rock on!!2005 SV-211
Originally posted by mrbobolina View PostI spoke to a few shops and everyone said the same thing. If the bearings are not exposing any copper color, or damaged, then leave them be. Thank god for one piece of good news. After futher review I have zero confidence I would have reached the bearings to where they needed to go be reaching up the oil tank around the crank and pistons.
Be sure to lube it all up with the proper Lubriplate brand engine assembly grease to prevent scoring during assembly and/or start up.
http://www.lubriplate.com/products/g...ly-grease.html
if you have good oil pressure leave the cam bearings alone.
I also agree with Trbenj on the cam, talk to cam research and he will grind a cam for you. He's done dozens for the boats over on CCfan including mine and I believe he's less than $300 for cam, lifters and a break in service. That's hard to beat. He has ski proven cam grinds that he uses but would also do a custom, I turn one of his cams around 5600 rpm and make 380 hp out of a 351 and it still idles and skis like a dream.
Cam research is what I chose. It was more costly than CompCam and Crane/Summit. Cam Research will do the breakin which is awesome and I can use my stock springs which the other two recomended to change out.
Should be here next week. Right now I am painting the motor and all the parts with por15 black and alluminum color. No more rust, not more leaks and moving forward no more issues - fingers crossed.
The block will be balck, as well as all of the fresh water cooling parts. The headers, valve covers, and manifold will be alluminum. That is the plan at the moment anyway. I could change my mind if it does not look right and go all stock black. I used por15 when I refabricated my trailer last year and the paint is senstional.
Cam Research Specs
Cam just got here today. It will be a few weeks still before I get the boat in the water to feel the gains.
Below are the specs.
Part Number CR202
Valve lift - .49 intake .49 exhaust
Duration - 282 intake 290 exhasut
Duration @50 218 intake 222 exhaust
Valve timing
Intake BTDC 1degrees OPEN ADDC 34Degrees CLOSE
Exhaust BBDC 49Degrees OPEN ATDC -4Degrees CLOSE
LOBE Seperatin 110 Degrees
REcomended Valve Spring Data
Install Height 1.850 lbs. 90
OPen HT 1.350 lbs. 290
Comp Cam and Crane Cam recomendations are on previous post on this chain.
.490/.490 is the same CR stick that Im running. Its quite a bit warmer than stock- Im assuming you know that. The ignition/fuel system can *probably* compensate for the difference, but that is one thing I am not certain of.
I suspect you will be very happy with the way the boat performs with it.1990 Ski Nautique
NWCT
crane makes all the cams
too bad they went under 2 years ago
HUMAN BUILT = HUMAN FIXED
switchbait.com
