06 Super Air Running Problems or Perhaps just gauges?
  • OnlyNatique
    • 84
    Hey guys,
    I got an 06 Super Air that I just had sumerized. Took it out on the water for the first time and when I started it everything sounded fine. I noticed that the Oil Pressure was at 80 and the Fuel Gauge was at E. I filled up the tank so I know I had gas. The other gauges were working, except Perfect Pass would not even come on.
    When I started to take off the boat started to go, then shut down and would only idle. I had no throttle in Reverse or Forward. After going back to the dock I shut it off, started it back up and I again had throttle but decided not to run it.
    You guys think this is due to the oil pressure gauge being at 80? Is there a sensor that shuts the motor to idle?
    Any advice would be appreciated. Has anyone has this problem happen?
