Does any one know where the ambient temperature probe is located , on a 2010, 230 super air, that's read on the LINC system display.
air temp probe
2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro airTags: None
Not sure on a 2010, but on my 2002 SAN it was located behind the dash, connected to the digital gauge with a single wire. Might be a good place to look first on your boat. I think they put it back there so it stayed out of the sun and gave (slightly) more accurate readings. Good luck...
As I recall, the air temp feature isn't operational in the 2010 Link, but the option still displays? I heard that was to change for 2011? Either someone will pop in with the answer, or PM clemsondave, as I know he's up to speed on the system.'08 196LE (previous)
'07 196LE (previous)
2 - '06 196SE's (previous)
It has been working fine up until last week . it was reading 95 and temp was around 75 . I am thinking the probe might be resting on a small light or picking up heat from an out side source If I knew were the the probe was located I could check it out.2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
