Flush pro vibrating
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    Flush pro vibrating
    When hooked to hose the clear plastic piece that says flush pro vibrates like a son bit#*. Anyone experienced this?
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    I have, and thought that was where air was leaking into my system, but it turned out that it was vibration of the one way valve and the hose pressure. I was also hearing a bit of a whine. Turns out the leak was at the raw water strainer.
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
    • gride
      • Jun 2007
      • 1441
      • War Eagle
      • 05' 210 team
      Thanks. I took the strainer off and checked o ring and re installed. Haven't had time to test it. Let u know what results are
