2000 Sport Nautique Speedometer
  • dwp
    • Oct 2010
    • 3
    • Halfmoon, NY
    • 1986 Martinique 2000 Sport Nautique
    Could anyone advise as to how to start to replace the pickup (Pitot) tubing from the outside of my 2000 Sport, to the speedometer and what may be involved? I can see so far that it looks like the ballast tanks need to be removed, but what about the "equalizer" I have been reading about?
    Can anyone provide me with some insight??
    Thanks,
  • dwp
    • Oct 2010
    • 3
    • Halfmoon, NY
    Well, after further research I have found that I have a digital Speedometer, which has a "thru-hull" paddle wheel assembly. Now my question is: what should I look at to see why it is not working? Because it is not. Do these need to be cleaned every so often or are they prone to electrical shorts? I do require a speedometer.
    Please send help!
    Thanks,
    -dave
    • MNkneeboarder
      • 6
      • Chanhassen MN
      • 2000 SN
      Did you ever get a solution on this?
      • dwp
        • Oct 2010
        • 3
        • Halfmoon, NY
        Hi, Yes I did, I bought a Faria GPS Spedo after replacing the Paddle wheel sending unit three times. I think I finally nailed it down to the Pot (volume switch adjuster under the dash, it was bad). I have sold both my Correct Crafts, unfortunately (Momma no like the rear facing seat) and got a 2006 Bryant OB 219, great boat also, but not a Nautique.
        I had a bad spedo in the Bryant also, changed that to a Faria GPS and never looked back.
        Peace,
        -dave
