Removing the ballast pump timer on 2011 SAN 230 TE
  • ironj32
    • May 2011
    • 601
    • 2018 SAN G23 XR550
    I'm wondering if there is a way to remove the timer setting on the ballast pumps on a 2011 SAN 230 TE? I've removed the rear factory hard tanks, and have replaced them with 1100 pound Fly High bags. It takes about 4 cycles to completely fill them, so I'd like to just remove the timers. Hopefully this is something that can be done!
    Thanks for any help you can offer.
    2018 SAN G23 XR550
    2015 SAN G23 XR550
    2014 SAN G23 XR550
    2013 SAN G23 XS550
    2013 SAN G23 ZR450
    2011 SAN 230
    2010 SAN 230
    2000 XStar
    www.mnspringride.com
  • TRDon
    • Oct 2007
    • 722
    • MN
    I would also like this information please
    • ers906
      • Feb 2010
      • 921
      • Phoenix AZ
      http://www.wakemakers.com/mastercraf...er-module.html
      Not sure if you can remove the timer, but this may be an alternative
      Eric, Phoenix AZ
      G23 550 hp (finally here)
      2002 Super Air
      • stegeler
        • Jul 2010
        • 3
        • 2007 236 Team Edition
        Location of ballast timer for 2007 236?
        What is the repair strategy for fixing a ballast switch that only pumps out water? The fill doesn't work. I've swapped pumps, etc and isolated it back to someplace behind the plug that connects it to the Jabsco.
        It doesn't appear it provides voltage in the fill direction.
        I'd actually be ok removing the timer entirely because I have piggybacked some fat sacs onto the factory hard tanks. Or maybe buy the newer timer from wakemakers.
