Strainer seal gasket
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    In 16 years of Nautique ownership, I have never once not hooked my finger over the top of the strainer when dumping it, nor not verified it was still there. Well, after launching my boat for the first time of the year Saturday to pull my lift in, I noticed the temp gauge rising. Went back to check the hose connection I had removed to summerize the engine. It was fine, then tried to tighten the strainer bowl and it was a bit loose. Removed to look at it and NO seal. Warmed up the Python but not too bad.... about 210 or so... Oops.
    Just a note of warning to always look and make sure it is there. Obviously I failed to do so. $5 problem could have been a $7-8k problem if I wasn't paying attention....
    the WakeSlayer
    1968 Correct Craft Mustang
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Sound advice as always. Thanks!
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      While doing some fuel pressure testing yesterday, I noticed my strainer leaking. I ordered another oring today, before taking it off. Hopefully that's all it is.
      Previous:
      2011 Super Air Nautique 210
      1994 Sport Nautique
      • 2004196
        • Dec 2007
        • 162
        • University Place, WA
        • 2006 196LE
        Strainer O ring
        I keep two spare o-rings looped over the oil fill tube just for this reason. I dumped my strainer overboard a couple years ago and watched the o-ring drop into the lake. Won't do that again but just in case! I also keep an extra bowl and screen in the boat as well but that is a different thread.
        2004 196 LE Black/Grey
        330HP Excalibur Water Churner
        2002 Grey F150 Harley
        475+HP Supercharged Tire Burner
        • WakeSlayer
          • Sep 2005
          • 2069
          • Silver Creek, MN
          • 1968 Mustang
          epilogue
          Just a follow up post.
          I was gone on vaca. Came back and had a new strainer seal in the mail. As I was installing this, naturally, I found the "lost" one way down in my bilge. Ran for a couple minutes floating in the lift. Temp spike again. Definitely smoked my impeller. I always, always have a spare. I had shredded half my vanes off. Replaced the impeller, and all is good. Running 160*. I should probably chase down the pieces I am missing, but I did not have the right tools on me to pull the stat hoses.
          the WakeSlayer
          • bchesley
            • Feb 2006
            • 1252
            • Tyler, Texas
            Glad to hear your back in order, but it amazes me how easily the impellers fry on these big blocks. My GT-40 motors would run for 5 minutes with out water and not hurt the impellers. I fried one in about 30 seconds chasing an air leak in my boat. It turned out to be the fresh water flush, which are junk if you ask me. I am up and running now and all kinks have been ironed out. I am going to PM you a few questions though.
            2001 Super Air Nautique
            Python Powered
            100 Amp Alternator
            Dual Batteries
            Many upgrades coming...
