Blowing 30amp fuse by isolator on 2001 san.
  • hyparks
    • Feb 2011
    • 302
    • Brownhills, United Kingdom
    • 2001 Super Air 210
    There's a 30 amp fuse in its own little holder next to the main isolator by the driver feet. In 4 outings on the boat this fuse has blown twice. Didn't have anything on other than stereo and perfect pass. Stereo has its own 10 amp fuse so think that would have blown first.
    Any ideas?
    Sent from my Desire HD using Tapatalk
    Current
    2001 SAN 210, GT40
    Previous
    1994 Mastercraft Pro Star 190
  • mrbobolina
    • Sep 2008
    • 107
    Bad ground somwhere. Ground may be tight, however the connected may be on corrosion or paint between. If your pp and stereo are the only two things on the line, check all the lines and look for one that may be lose. Good times.
    • hyparks
      • Feb 2011
      • 302
      Ok thanks. I did find perfect pass live and earth wires coroded so cut them back and re connected. Stereo seems fine but need to try and get to the amp because that does not look the best. The amps behind drivers foot board with all breakers on it. Need to start removing wires and breaker box etc to get to it though. Not good. Lol
      Current
      2001 SAN 210, GT40
      Previous
