My 08210 has a fresh water flush on the back of the boat. Can I use that as a "Fake-a-Lake"?
Tags: None
I have one of those on my 01 210. Got hose pipe connection teed into it with a shut off valve in line.
Connect hose up open valve and away you go. Home made fake a lake.
Sent from my Desire HD using TapatalkCurrent
2001 SAN 210, GT40
Previous
1994 Mastercraft Pro Star 190
Yes
Short answer is yes... this is a built-in fake-a-lake. According to the manual the engine should be running while you flush... in fact it states that you need to shut off the water supply quickly after turning off the motor to avoid engine damage. The manual also states that you should run it long enough to get up to normal operating temperatures to ensure proper flushing. I've done this - works great.Derald
2011 SANTE 230 CE (April 2011 - now)
2006 SN 196 LE (February 2007 - March 2011)
