Engine Compression Help!
  • kateye57
    • Jan 2005
    • 26
    what is considered to be good engine compression when shopping for a used boat with about 500 hours?
  • polkaking27
    • Jan 2005
    • 104
    anything over 100 is considered a good compression as long as all cylinders are within about 10-15 psi of each other. so if you had compression of 110, 150,155,146,142,148 that would be bad because 1 cylinder is more than 10% off
    if con is the opposite of pro, is congress the opposite of progress???
