Keypad Issues?
  • Flipside
    • Feb 2009
    • 137
    • Portland, OR
    Keypad Issues?
    I have an 01 SAN. Tried to start my boat for first time this season but could not get keypad to work. I checked battery connections and all is good there. The bilge fan and pump work, and the horn works. When I touch a button on the dash, the console lights up so I'm getting power to it. All the breakers are fine. When I depress the keypad, the green light in the lower left of the keypad illuminates except when I touch #4 which unfortunately is part of my code to start!
    Any pointers?
  • jkvvlv
    • May 2010
    • 11
    • Eustis, FL
    • 1992 BareFoot 2003 Super Sport 210
    Keypad Issues?
    Try the orriginal factory code. If it does not contain a 4, you might be in luck. With it you can change the code to what ever you like.
    Good luck
    • Flipside
      • Feb 2009
      • 137
      • Portland, OR
      I bought the boat used. I am not sure I have this code. Is there any way to find out what the factory code is - other than calling Nautique?
      • Bevan
        • Mar 2007
        • 439
        Your local Nautique dealer can get this for you. I didn't know my code either so my dealer jumped on the web and had it for me in 2 minutes flat!
        • aggiehorsepower
          • May 2011
          • 17
          • Elgin, Tx
          • 2001 Super Air Nautique V-Drive
          I believe the factory code is 43431
          • Mazza
            • Jul 2009
            • 30
            Same problem. and what was wrong
            had the same problem with a SN 2000. it turned out it was a bad soldering on the print in the keypad
            try to take all power off.
            Normally when you press any key other than the start button. the Backlight should come on at all keypad on the keypads. ( Red Background Light on my boat)
            On mine, the 4 key and the start button was not functional.
            If NO backlight comes on when you press the 4 button, there is no connection. And you need a new Keypad. Unless there is no guaranty. then you could try to fix it as it is a rather expensive part.
            Also try to disconnect the keypad and measure if any signal is comming true when you press the ”4” key
            Fortunately for me i had just replaced the original keypad last year, with a brand new one. So my local Nautique dealer gave me a new one on the guaranty.
            • hyparks
              • Feb 2011
              • 302
              • Brownhills, United Kingdom
              • 2001 Super Air 210
              I had similar problems but with the accessory keypad. Certain buttons not working. Removed keypad, removed rubber pad from the circuit board. Sprayed circuit board with electrical switch cleaner and re fitted the pad. All keys now working. May not work with yours but definitely worth a shot if you got no warranty
              Sent from my Desire HD using Tapatalk
              Current
              2001 SAN 210, GT40
              Previous
              1994 Mastercraft Pro Star 190
