no speedo and tac lights
  • Al
    • Sep 2010
    • 28
    • 05' Air Nautique SV 211
    05' sv 211
    I tried to arrow up on my tac and still no lights everything else has lights any Ideas
  • bj25430
    • Aug 2009
    • 65
    • McAlester, OK
    • 2008 220 SANTE - Current - 2006 SV211 TE Air Nauti
    The arrows worked for me. 2006 211. I think its pretty common they get turned down. Good luck
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      I had a problem with the bulb on mine not making a good connection. Have to pull the dash to fix it. The bulb when rotated into the "lock" position lost contact with the dash panel. I ended up soldering a little wire to it.
      2005 SV-211
      • Al
        • Sep 2010
        • 28
        I fixed it!!!!
        I found the connection on the box in the rear star side had a plug with dash lights marked so I pulled and cleaned and now it works fine
