2003 Air Nautique 216 DD
With the Ball valves closed (engine compartment with the blue handles) I will get one side (usually port) that will partially fill with water. We will be sitting in one place for a while, and when we take off, the boat lists and I know one of the tanks started filling. (the water gauge shows its 1/4 or so full) So I then switch the pumps on to drain, and water will pump out for 30 sec- 1 min.
Same thing will happen 3-4 times over the course of a day.
Why is this??
Side note: My pumps are not working to pump water in. Apparently they can pump water out though?
Why is this??
