wrong installerd battery .. :(
  • danielm
    • May 2011
    • 2
    • hamburg,germany
    hello,
    yesterday was a bad day for me.
    we went out to the boat with a new battery. while i was filling the tank, my brother connected the battery on the wrong battery terminal.
    i did not checked it. my fault.
    so i started the boat and the battery goes boom ...
    now the boat wont start anymore... still i have power on the boat .. gauges are working..
    music is working .. pumps are working!!
    what could have happen`? Do you think the starter is blown away?
    Please help )) me
  • scuff97
    • Sep 2010
    • 52
    • 1992 sport nautique 2007 SV-211
    What year engine do you have? If it is 2007 or above there is a 100 amp fuse wire that protected the engine. This 10 gauge red wire runs from the starter.
    • danielm
      • May 2011
      • 2
      • hamburg,germany
      it the excalibur 330hp
      • scuff97
        • Sep 2010
        • 52
        In this case the wire goes from the starter to the circet breaker. Verify that you have 12 volts to the circut breaker
        • GoBig
          • Apr 2008
          • 551
          • Santa Cruz, CA
          You may have fried your engine wiring harness and it is shorting out. I'll post a pic later of my buddy's boat showing his EX330 PCM wiring harness after the batteries were connected backwards. Pull away the plastic sleeving and check the condition of your harness...
          2003 SANTE
