How can I repair this?
  • Adrian
    • 175
    • Spain Europe
    The picture is not so good but you can see a deep crack in the hull and some tape "bitten".
    I've part of the tape lost too (not in the pic)
    How can I repair both "disasters"?
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    RE: How can I repair this?
    You can pick up a gelcoat repair kit from West Marine for fairly cheap. Color matching is the hardest part. Mix up the white and see how it matches by smearing some on the gelcoat not necessary on the place to be repaired to see how it'll match. Do the best you can then fill in the hole. Once try, wet sand and buff.
    The tape is super easy, you can either replace the whole side or just the section. Use a razor blade and cut out the offending section. and then lay down the new pin striping, stand back a bit to make sure you're laying it straight, then stick it down. There is a very thin film on the top of the tap, peel that off and you're good to go.
    The tape is just good old automotive 1/4" pinstriping tape found at your local automotive parts store.
    Chris
    • Adrian
      • 175
      • Spain Europe
      Thank you very much, Chris.
      You really helped me.
      • hsmunoz
        • Nov 2004
        • 191
        • livermore
        Adrian,
        here's a link that has facotry Nautique color repair kits.
        CC recommends them, just pick your year and color
        http://spectrumcolor.com/catalog.htm
        regards
        henry
        2004 SV-211 Team
        Silver cloud deck, Onyx Hull.
        • Adrian
          • 175
          • Spain Europe
          Thanks Henry.
          Anyone knows what color is that one?
          I can't see any white (1998) in the list, could it be neutral?
          http://www.spectrumcolor.com/categor...=CORRECT+CRAFT
          • whataniceboat
            • Jan 2005
            • 18
            • Hertfordshire (UK)
            its called silver cloud
            make sure that you order the right one for your year boat
            • Chopper
              • Jul 2004
              • 92
              • Brisbane Australia
              • 1989 Ski Nautique SN2001 1991 Ski Nautique 196 1998 Ski Nautique 196 2003 Super Air Nautique
              I have the same problem with my 98 ski. So just to confirm, the white colour is silver cloud, and the beige colour is neutral.?
              Has anyone used this company.? How close is the colour match.?
