The plug on the bottom of my FCC has become rounded off does anyone know where I can purchase a replacement plug?
Tags: None
Call White Lake. Not sure if that part can be sold by itself, but they will know for sure.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
thanks for the replies will try White lake. I need whole fitting due to the fact I cant get plug and the rest of assembly to separate.
Originally posted by treverspence View Postthanks for the replies will try White lake. I need whole fitting due to the fact I cant get plug and the rest of assembly to separate.
2. Take the whole tank off and use some vise grips on the plug. Just clamp down on it.
3. Maybe hack saw it in half down the middle and peel it out.
4. If the treads strip out, you might just drill and tap it to the next NPT size with cheap taps from Harbor Freight.
5. Or, just give up and not use the drain. Slip a pitcher under the FCC tank as you take it off to catch the gas.
