Bilge pump in stern not working: 2005 211
  • Vector
    • May 2011
    • 35
    • CT
    • 2005 221
    I would like to isolate the problem with my inoperative stern bilge pump and would appreciate advice on the proper steps. I am not sure if it is an electrical issue or if the pump needs to be replaced. Can anyone tell me the the best method? Thank you.
  • Al
    • Sep 2010
    • 28
    • 05' Air Nautique SV 211
    test
    turn on the pump and use your test light to see if you have any power, if you have power check to make sure the connections are cleaned with contacted cleaner and a small brush, recheck if still no pump action I would think is needs to be replaced.If you have no power it could be the key pad switch. hope this helps it worked for me
