Cleaning Products Help - Carpet and Vinyl
  • Blamey
    • Sep 2015
    • 595
    • New York
    #46
    Originally posted by brownt2
    On a side note, curious what you guys have used (and found effective) cleaning up the hull with after a weekend in the water? I have used a "homemade recipe" given to me by a family friend that seems to work just "okay." Look forward to hearing your responses.
    I find that what you use depends on where the boat is kept. Mostly it's about where you need something with a light acid (usually vinagar) for water spots, something like Hot Sauce or if water spots are not an issue where you are then just a cleaner with wax like Babes Boat Bright.
    There are several home made recipes floating around mixing liquid waxes and vinegar etc. I just get Babes as I don't need the vingar because we don't get water spots where we are.
    • Dgee
      • Jul 2016
      • 137
      • Portland, OR
      • 1999 SAN
      #47
      Originally posted by cdrymalla View Post
      I have not found anything better than Malco for the vinyl. I have used it on what I thought was clean white vinyl and ended up with the water looking like chocolate milk and the vinyl and threads taking on a super bright white look. The stuff is great. I bought a spray bottle along with a gallon jug and although it is a bit pricey, it last a while. I also use 303 protectant afterwards.
      I have to agree on the Malco, the stuff is fantastic!
