GT-40, shredded impeller, overheated and now it won't turn over...
  • sperbet
    • Aug 2004
    • 283
    • Truckee, CA
    Any advice? I'm about to take it into the shop and am fearing the worst. Anything I can mention when I take it in?
    Ummm, I\'ll take the REAL 210 please. Thanks.
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    How bad did you overheat it ?
    the WakeSlayer
    1968 Correct Craft Mustang
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      Its probably hydro locked due to the overheat. They will suck water back through the exhaust if they get hot enough. Pull the plugs and spin the motor over a few times.
      2001 Super Air Nautique
      Python Powered
      100 Amp Alternator
      Dual Batteries
      Many upgrades coming...
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        And do it soon. Little oil down the cylinders too.
        the WakeSlayer
        • surroundsound64
          • Jul 2005
          • 2147
          • Longview, TX
          • 2018 230 1981 Ski Nautique
          A little marvel mystery oil will work good as well. Just put in a squirt bottle and spray into the holes. Let it soak a bit then turn it over.
          2018 SAN 230
          1981 Ski Nautique
          Sold - 2011 Sport 200V
          Sold - 2000 SAN
          • sperbet
            • Aug 2004
            • 283
            • Truckee, CA
            Just wanted to update this in case someone has a similar problem in the future and searches the forum. I didn't find a whole lot of information in my searches.
            I originally feared I had seized the engine. It was hydrolocked. We pulled the plugs and turned the engine over which shot water out. It had water in three of the cylinders. My friend who helped me with this thought the head gasket was likely blown. It then went to the shop. The compression was all normal indicating no blown head gasket, but there was water in the oil. They ran some sort of oil/solution mix through a few times and then changed the oil three times. Boat is now back and running fine much to my relief. Ended up costing a lot less than I originally expected.
            • Texan1554
              • Apr 2011
              • 220
              • Dallas
              • 2002 SANTE
              Good to hear it, thanks for the update.
              2002 SANTE
                Many years ago, I flooded a Honda 125 four stroke motorcycle fording a stream. After draining the exhaust pipe, and removing the spark plug, it started and I rode it home, and changed the oil. It was fine.
                The real 210 is a Super Air. Unfortunately, Correct Craft quit making it in 2006.
                • horkn
                  • Aug 2007
                  • 270
                  • WI
                  Been there done that too. Exactly the same way as yours, except mine is about 25 years or so older. Hydro locked and it only needed to be drained and have new oil put in it. The sooner the better for draining any hydro locked motor.
