Voltmeter reading 12 volts instead of 13.5 - 98 Sport Nautique GT40
  • JimHughes
    • May 2011
    • 21
    • Thousand Oaks, CA
    • 1998 Sport Nautique
    First time out for the summer last Saturday and twice the starter sounded like it didn't have a full boost of power. Fortunately it started both times after I waited a moment. I noticed that the voltmeter was reading 12 volts instead of its normal 13.5 volts. The other year, the engine drained the battery after a few hours (it was reading 12 volts) and stranded us in the middle of the lake. Unfortunately, I can't remember how I fixed it! The battery is only a year old.
    We are going boat camping in 2 weeks so I need to fix it SOON so I can test it next weekend.
    Your advice is GREATLY appreciated.
    Thanks,
    Jim
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    if you mean your voltage gauge, do NOT go by that. Use a multimeter at the battery terminals. Check your connections, and clean them regardless of what they look like.
    Do a search, there are dozens of threads you can find about this kind of stuff.
    the WakeSlayer
    1968 Correct Craft Mustang
    • JoeSki
      • Jun 2011
      • 20
      • Dutch Lake, MN
      I had a very similar experience with 98' sport last summer. I did everything Wakslayer suggested but was still having the same issue (with a new battery). Turns out the solenoid at the back of the motor was shot. We replaced it and its be running perfect since.
      1998 Sport Nautique (Current)
      2000 Pro Air
      • JimHughes
        • May 2011
        • 21
        • Thousand Oaks, CA
        Thanks for the tips.
