2006 211 Dash Board Removal Question
  • gnautiqueman
    • May 2006
    • 47
    How do you remove the dash board to replace a gauge (perfect pass), boat is 90 miles away so I can't crawl around on it and figure it out now. the boat is a 2006 211. thanks
  • sjames
    • May 2009
    • 219
    • California
    D
    Does it look like this?
    If so two screws on the top surface by windshield and one on each corner near the bottom edge. Then just pulls off
    Do the right thing.......
    • gnautiqueman
      • May 2006
      • 47
      Yes, that's it. Thanks.
      • Chexi
        • Apr 2025
        • 2119
        • Austin
        • 2000 SAN
        Don't forget to take the steering wheel off first.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • gnautiqueman
          • May 2006
          • 47
          Good point. I'm assuming there is a nut under the cap in center of steering wheel.
          • Chexi
            • Apr 2025
            • 2119
            • Austin
            • 2000 SAN
            Likely 6 to 8 Allen head bolts. Bring an Allen wrench set with you.
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
            • sjames
              • May 2009
              • 219
              • California
              Was able to tilt my wheel down enough to get to the gauges if you want. But very easy to get the wheel off as well.
              • Chexi
                • Apr 2025
                • 2119
                • Austin
                • 2000 SAN
                ... and easier to work on with the pod off completely. Once you get the wheel off, it is probably just a few harnesses to detach unless there is a bunch of custom stuff in there.
                Now
                2000 SAN
                Previously
                1999 Air Nautique
                1996 Tige Pre-2000
