portable hose to remote ballast
  • johnboyy7
    • Oct 2009
    • 409
    • houston
    I still use, as many still do, portable fat sacs on the seats. im tired of using the 'over the side' pump and the time it takes to fill 3 bags individually,plus i cant fill on the go. Thus here is my solution, let me know what you think or if you have suggestions.
    my current setup. aerator pumps (not going to puppies, so please dont mention) for fill and empty 750's in the lockers with 'cup' pick ups on the boat bottom. works great. boat is 04 sante 210.
    my plan.... 'T' into the discharge of the fill pump with 1'' hose and 'T'. run hose around to the side of the back seat through the breather passage for the motor, im guessing thats what it is or called, and come out where the 4 cup holders are by the ice chest. i plan to put a quarter turn valve at the end then my fitting to fill the bag. im thinking i want the valve at the end by the bag fill vs. at the pump is for simplicity.... dont want to open the hatch everytime. when done using my fill hose i plan to push it back into the cubby hole so it is out of sight.
    now for the bow 'fill line'. i plan to 'T' off of belly fill pump discharge, run hose over to either the drivers side or up through around under the observer storage compartment (if that is even doable). then run the hose up through one of the cup holders. im thinking cup holder so i can push the hose back down when i dont need it. i thought about just having it under the cushions but that means you would have to move a cushion and deal also with the bag on the seat too.
    thoughts??
    04 SANTE 210
    89 SPORT
