hey i have a air 206 and im fitting a ballast system everything is set up to go but i dont know how to get power from the fill and empty switches on the dash please help......it was not factory fitted but the pod with the switches seems sealed
RE: dashpad switches
What year is your boat, this should be a simple thing to do. If the boat is 2003 or later then look on the port stringer for wires tied up by the front of the engine and by the back of the engine. The one in front is fill and the one in the back is drain.
If you have a 2002 or earlier look behind the drivers kick board for a big bunch of wires. You will be looking for a set of wires (orange w/ red tracer & orange w/ yellow tracer) these are fill and drian and what ever year you have these wires will power your pumps from the key pad
Originally posted by RickBrad trust me, Frost knows. If they don't have power see if the breaker at the box is popped. Also try between one of them and ground or the other. I found mine right where Frost said they would be.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
