replaced impeller & still heating
  • tarttart
    • Jun 2011
    • 3
    • Wade NC
    • '88 2001
    Bought an '88 2001 from broker in Dec. installed flush pro. ran in salt water 1 time. flushed. took to lake & it heated. replaced BADLY shredded impeller. took to lake & heats on trailer. anybody know what other problems/solutions could be?
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Did you fish out all the impeller bits from the cooling system?
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • CradGen2
      • Aug 2020
      • 1343
      • Horseheads NY
      I agree with chexi. Also make sure you don't have air leaks in the flush pro
      • Nautiquehunter
        • Jun 2008
        • 2080
        Make sure you didn't put the pump on upside down . If its a 351 the pump should be mounted with the hoses on the block side.
        • tarttart
          • Jun 2011
          • 3
          • Wade NC
          • '88 2001
          no. never had an inboard. thanks. its in shop. expensive lesson I bet.
          • Chexi
            • Apr 2025
            • 2119
            • Austin
            • 2000 SAN
            Yes, definitely check the orientation of the pump (if you took the pump completely off when changing the impeller). On these old Fords it is possible to put them in upside down, in which case they spin but you get no water to the engine. Maybe not a bad idea to check just in case anyway. The last person might have gotten it wrong.
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
