1995 EFI Throttle Body Issue
  • Derek
    • 1
    • Seven Lakes, N.C.
    • 1995 Ski Nautique
    I have a 1995 Ski Nautique (425 hours on it now but bought it new) with the 351 PCM EFI engine. I've had a couple instances where I run for a couple hours then sit for an hour or so. When I go to restart, the engine cranks, then acts like it chokes and stops. I can try to re-crank it, but all it does is spin the engine....failing to fire. I had originally thought it was out of gas (have added a couple gallons and then had it to start in the past) but since then have found the tank to be almost full. I'm not sure if it's a venting issue or possibly a fuel pump problem. Has anyone experienced this issue?? And if so, what are my options?
    Derek in N.C.
  • mnwild2
    • May 2010
    • 80
    • Twin Cities, MN
    • 1995 Ski Nautique 196 CB, EFI - Sold 1999 Four Winns Horizon 170LS 4.3 Litre - Sold
    Derek, I haven't experienced this issue, if I do, I will let you know the resolution, Thanks.
    1995 SN 196(Sold)
    GT-40
