Long crank before starting
  • jasper
    • Feb 2005
    • 195
    2002 GT-40 When cold, must crank multiple times about 4 seconds before it will start. Once warm, no problem starting. Problem is very consistent. I've not been able to check the fuel pressure yet, but wanted to see if anyone had a similar experience and solved the problem to help narrow the possibilities. I'm thinking high pressure fuel pump or fuel pressure regulator. I don't have a star tester to check codes on the air charge sensor or the engine coolant temp sensor. Any ideas are appreciated.
    Jasper
